Spotify Connect not working with VMG3927
Coltrane100
Hi! I have problems with getting Spotify Connect to work with VMG3927-B50A.
I have Marantz NR1050 AV receiver connected to the VMG3927's WiFi and I can the Marantz AV receiver in ZyXEL's connectivity dashboard correctly and other networking services on Marantz work fine. I can also see Marantz in Spotify app as Spotify Connect destination on all my devices correctly. However, when I try to active it the connection is never established (it just keeps trying and trying).
I have tried the same setup with two other routers and there’s no problem so I believe it’s something related to VMG3927 networking settings.
I found this Zyxel support article that might be relevant but VMG3927 settings look totally different so I can't follow the steps. I have also tried to enable local logs on VMG3927 to check if I can find something but I don't know how to view them.
Any help to troubleshoot would be highly appreciated!
Believe or not but the solution was to power cycle Marantz i.e. unplug the power cord from wall for 10 secs and then plug it back.0
if you are ford employee checkout my fordbenefits. https://my-ford-benefits.live/
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
