USG 310 hosts real time bandwidth
Briz
Briz Posts: 20 image  Freshman Member
How is possible to see in realtime current bandwidth used by the hosts?
  • Zyxel_Cooldia
    Hi @Briz,
    It’s not real-time bandwidth usage. It does not support real-time bandwidth usage on specific IP at current design.
    In the Traffic statistics and Session monitor are accumulated bandwidth usage. You can get the highest bandwidth usage by clear/flush data to get latest accumulated bandwidth usage.
    edited May 2021
    In traffic statistics and interface lan1 by host IP you can see the amount used for Tx/Rx
  • Briz
    this is the total amount of traffic used for the session, not the real-time bandwidth used at that time from host, right?
  • Zyxel_Cooldia
    Hi @Briz,
  • Briz
    ok thanks, do you plan to add this important information in the near future?
  • Zyxel_Cooldia
    edited May 2021
    Hi @Briz,
    Thanks for valuable suggestion and we will evaluate it in the future if it is beneficial. =)
    This topic has been move to idea section :
    https://community.zyxel.com/en/discussion/10636/real-time-bandwidth-usage-base-on-ip-address#latest
