USG 310 hosts real time bandwidth
Hi @Briz,
It’s not real-time bandwidth usage. It does not support real-time bandwidth usage on specific IP at current design.
In the Traffic statistics and Session monitor are accumulated bandwidth usage. You can get the highest bandwidth usage by clear/flush data to get latest accumulated bandwidth usage.
In traffic statistics and interface lan1 by host IP you can see the amount used for Tx/Rx0
Hi @Briz,
ok thanks, do you plan to add this important information in the near future?
Hi @Briz,
Thanks for valuable suggestion and we will evaluate it in the future if it is beneficial.
This topic has been move to idea section :
https://community.zyxel.com/en/discussion/10636/real-time-bandwidth-usage-base-on-ip-address#latest
- 603 USG FLEX H Series
- 481 News and Release
