NSA 542 - not able to connect via Browser after latest FW upgrade
ToRtiK
Hi - after the latest FW upgrade ( V5.21 (ABAG.7) ) I am unable to connect to the web UI nor on MAC (using Chrome, Firefox or Safari) nor WIN 10 (Chrome, Firefox, EDGE) - the NAS is running - the cables and ports on the NAS + Router are working and I can connect to it via a file browser (MAC - ForkLift / WIN - Total Commander) - but I am unable to access the WEB UI - any suggestions?
Do you have ssh access? In that case you can try to restart the webinterface manually, to see if it shows an error:su/etc/init.d/httpd.sh restart1
Hi - In fact I don't but will try it - just have to refresh how to connect via SSH :-P0
In that case it won't work, as you have to switch on the ssh server on in the webinterface first. I think you have 2 options, use the Universal USB key to get telnet access, for the same investigation, or simply perform a factory reset.0
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
