factory reset wont work
flashes green & orange always0
Are you doing the reset with the AP powered and hold reset in for a good 20 seconds?
yes AP is powered, hold reset till lights change , still no reset
It used to work I've reset it before0 -
Hi @allenmAccroding to your description, the LED status is flashing with orange and green. It meanse the AP is booting up or searching for the NCC/controller.
If you used reset button, the LED status will be steady orange then flashing orange and green. Please let me know if you saw the steady orange LED.
After that, here is the SOP to let the AP back to standalone mode with default.
1. Remove the AP from the NCC inventory.
2. Ensure that the AP gets IP address successfully. If no IP address, check the DHCP server and environment. We also can use ZON to scan the devices. Install the software on the PC which is in the same subnet with the AP.https://www.zyxel.com/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
3. Connect to the AP IP address and realize if the AP is back to default.
If you want to use another way to let the AP back to default, you can refer to the below link. There are three ways to reset the AP via reset button, web GUI or via SSH.
https://community.zyxel.com/en/discussion/10612/how-to-factory-reset-zyxel-ap#latest
Please let me know if it helps.
Joslyn0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
