Zyxel Armor G5 - NBG7815
Thanks for valuable suggestion and we will evaluate it in the future if it is beneficial.
This topic has been move to idea section :
https://community.zyxel.com/en/discussion/10790/configuration-backup-for-armor-g1#latest
please add link aggregation beacuse without 10gb port ussles0
Hi @untq,
https://community.zyxel.com/en/discussion/10814/link-aggregation-function-for-armor-g5#latest
Hello Zyxel Team,This Armor G5 is still with an unfinished and bubby UI.When do you plan to provide something usable?Thanks,
Hi @gnivat
The NBG6818 and NBG7815 can register on https://mycloud-sso.zyxel.com
When login NBG6818 and NBG7815 it will register an account on the PCloud.
You can login the device by using the PCloud account to access the device.
The NBG6818 and NBG7815 are not able to register on https://portal.myzyxel.com/ or0 -
Hello Jerry,Thank you for your answer, but it concerns another post.Here I was asking if Zyxel is making any progress on the Armor G5 firmware ?When will we have a major (working) upgrade ?Thanks,Guillaume
Hello Guillaume @gnivat ,
There was some new firmware released for Armor G5 in November 2021, see https://www.zyxel.com/uk/en/support/download_library/product/armor_g5_19.shtml?c=uk&l=en&pid=20200121174046&tab=Release_Note&pname=Armor%20G5&mtname=Release%20Note
Does this help you?
Kind regards,
Tony0 -
Hi @gnivatGuillaume,
Yes, there was a new firmware released for Armor G5.
You can check the release note below.
https://download.zyxel.com/Armor_G5_(NBG7815)/release_note/Armor G5 (NBG7815)_V1.00(ABSK.7)C0.pdf
@tonygibbs16
Thanks for your sharing.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
