SSL Inspection Pages SLOW
Hi @jonatan,
We are already debugging in your site. Please kindly wait for updates.
Hi @Julien_ALM,
Can you please share your startup-config.conf file with me by private message?
I would like to test this case for you.
Hi, I also have slow Website loading with SSL Inspection on my FLEX 100, running the lates firmware.
Especially pictures on a website are taking very long to load, while you are visiting the site for the first time. Without SSL Inspection it's very fast.
Key Mode is: ECDSA-RSA-1024
Regards,
JO0 -
Motivio said:Hi, I also have slow Website loading with SSL Inspection on my FLEX 100, running the lates firmware.
Looks like this is certainly an issue with Zyxel and not our ISP's0
Hi @Motivio,
Can you share some information with us;
1- How long does it take to open a website with SSL inspection enabled and without SSL inspection?
2- Which website do you use for testing?
3- Can you try to update your signature?
(Configuration > Security Service > SSL Inspection > Certificate Update)4- Can you provide me remote access to a client in your network and admin account to your gateway by private message?
Hi @MPOster,
Do you mean USG200 or USG FLEX 200?
What’s the firmware version of your device?
@Zyxel_Can
I've tested with the following website:
https://bildarchive.motivio.de/archive
I run the Certificate Update manually. Even that it didn't change the version in the display, there was a change afterwards, when I cleaned up the "Exclude List" under SSL Inspection.
Now it seams to be ok.
I hope this didn't go stale -- I literally just shut off the SSL because I am sick of hearing the complaints but I want to get this fixed. My prior set-up was a Fortigate which uses the same system settings and I didn't have any issues with that one .0
Hello! Is there any progress on this topic?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
