Reboot ATP800
Hello, Anydesk is now enabled again for console connection, confirm if you can connect.I have captured the log as the video but there is no information per console when executing debug kernel console - level 8.The console does not show anything.Attached log of the capture.I'll be waiting for the next reboot0
Hi @Pedroj,
Thank you for your feedback.
I can access to console via AnyDesk software. Please kindly keep it running.
Tera Term software was set to capture logs. Please keep it running until next time issue occurs.
When next time issue occurs, please capture console(Tera Term) and diagnostic logs and send me.0 -
Hello, the ATP800 has restarted again, 10:45 AMThe reason:[439467.356565] Kernel panic - not syncing: Fatal exception in interrupt[439467.363018] panic_notify_sys Log Date: 1623750335[439467.367813] Firmware Version: 5.00 (ABIQ.2) | 2021-05-03 17:11:01[439467.373912] Kernel Info Collector: detect system crashed, store information in disk.And also when entering the ATP800 after the restart I see this:
I had to reboot again.I send you the Tera Term log and diag-log privately.We need an urgent solution to this problem as it is affecting us negatively with the client.The problem persists and the customer is very upset.Thanks0 -
Hello, it is already disabled.This will be for a long time? Deactivating this option is a security risk, there is no problem todeactivate it?
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
