Seriously, your ideas could be new feature for Nebula!
Zyxel_Carter
Zyxel_Carter Posts: 62 image  Zyxel Employee
First Comment Friend Collector Seventh Anniversary
edited July 2024 in Nebula Ideas
Hello Nebula Forum Members,
Do you have moments that if your own thoughts or ideas can make better experience when using Nebula?
<3 We can make your wish come true! <3
Simply start a new post here describing your fabulous ideas for features or services you wish to have!
Once your ideas get lots of vote  , we will give it to our product developers to have them evaluated and tell you the feedback!
Sounds cool?
Give Likes and Try it Now!
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    Please make it Possible to change WAN interface names On USG-Flex firewalls. Drives me crazy lol
  • Pook
    Allow ZTP fuction to specify desired port for WAN setup. For example I deploy to our workshop LAN on DHCP so WAN2 (P1 On Flex100) so we can run updates and soak test. Then when ready I can configure WAN1 for the deployment site.
  • Pook
    How about a ICS outlook file for Nebula License reminders?
  • Zyxel_Jason
    Zyxel_Jason Posts: 425 image  Master Member
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Pook,
    If you would like to share ideas that hope to implement on Nebula in the future, please create new idea post in Idea section, so other users can vote for your post if they agree with your idea.
    Thanks for your cooperation.
    Jason
  • JimboJambo
    JimboJambo Posts: 10 image  Freshman Member
    I’d like to be able to turn the led lights on and off on my access points via the phone app and also the maintenance wifi on my outdoor router after it’s rebooted.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,037 image  Guru Member
    Hi @JimboJambo,
    Zyxel Melen
Nebula Tips & Tricks
