Console port
dpipro
dpipro Posts: 73 image  ZCNE Certified
First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
edited May 2024 in Wireless
The NWA5123 series has a 4-pin console port. Where can I get the console cable?
Thank you?
BR,
Fernando Vieira
Best regards
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @dpipro
    Did you meet any question for NWA5123 series?
    For the console, you can buy it from amazon.
    Zyxel’s console header pin define: pin1 NA, pin2 White(RX),pin3 Green(TX), pin4 Black(GND), PS: Don’t connect red color pin to zyxel’s console pin.
    You can buy any USB-to-Serial Bridge TTL 3.3V for Zyxel’s console port, and reference header pin define to connect.
    Hope it helps.
    Joslyn
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    Whats the PIN out plan for the devices? Is it all the same?
  • Zyxel_CSO
    Zyxel_CSO Posts: 504 image  Zyxel Employee
    5 Answers First Comment Friend Collector Ninth Anniversary
    Hi @Pook,
    Yes, the PIN out plan is the same for Zyxel WLAN enterprise devices which use 4 pin console cables.
    Is there any problem when you use the cable?
    As previous post mentioned, please note that  DO NOT connect red color pin to zyxel’s console pin.  The pin 1 is NA, and please align it with the triangle mark of the AP console.
    Zyxel Nebula Support
