how to get rid of wizard in USG210 firmware 4.25 AAPI.1
how to get rid of wizard in usg210 firmware 4.25 AAPI.1
Every time I login I get a Wizard I have run the wizard many time s but it is the
it comes angian when I login to USG210 the firmware is v4.25 AAPI.1
Claus
Hello Claus_Kysthusene,
In this case, the situation should be disappeared if you register the device or UTM license. We want all uses register their devices because after registered, the device can update the latest FW from MyZyxel.com.
However, the case should disappeared, when you are on setup guide, press next until third step and you will see Skip button(Click it). After that the Initial Wizard will not appear.
Charlie
Claus_Kysthusene, sound strange.
I know that you get the "wizard" popup when you login to the product, but you can just click "exit" or "skip" to bypass the "Setup Wizard" and you will get the dashboard window. But this might require you to keep the product in "expert mode" once you have configured it, I do not know because I have always used the zyxel products in expert mode and never used the guides. I often consult the manual if I need help.
Charlie
In my case, running a USG60 w/ V4.31(AAKY.0), I tried the above steps and on the next login, the bloody Initial Setup Wizard was the first thing to greet me again... And, the USG60 IS registered!
This started happening after the 4.25 update and is rather irritating, especially since the USG60 IS configured, it IS registered and from everything I see, there should be NO reason I should have to see the Setup Wizard on every login.
So, is there a way to stop it from popping up, or is DennizOlof correct that the only way to get rid of it is to go to Expert Mode only?
Thanks in advance for your assistance.
LinearTechSvcs
@LinearTechSvcs i send you the solution in a pm
Maybe you should make this solution public as I've wasted an entire evening on a customer site trying to get around this issue. Why is the solution to this so private? ZyXEL have screwed up in m opinion allowing this issue to exist in a released version of firmware. There is no ZyXEL support at this time of night or over the weekend, so unless I find an answer somewhere else, I guess I'm stuffed! Not happy!!!!0
Hi @DaveCI've the following, known info about the question:
Question:
How do I get rid of the "Initial Setup Wizard"? This comes up with every login since the update, although the USG definitely has a full config ?
Answer:
After the update, perform a 'Registration Refresh' under 'Configuration - Licensing - Registration'. After that, the wizard should not appear again.'
Source:
ZYXEL private forum in Germany (reported from a ZYXEL employee)
Hi Christian,
I've the same issue on my USG 310, tried thousands of registration refreshes but the wizard is still there everytime I log on, is there something else I could do in order of get rid of this annoying situation ?0 -
I tried Christians suggestion on a customer USG40 (V4.30) and can't get rid of the wizard.
What about save your config and follow the wizard then once the wizard is gone load your config?
I had the same issue on a USG60W and it was solved by 'Registration Refresh' and after 24h runntime to sync with portal.myzyxel.comAfter this, the startup wizzard is no longer comeing up during admin logon.
@Line2
have you checked the registartion at myzyxel.com portal, where the USG is registered ?Regards
Chrstian
P.S.: I've 4.31 installed (solved the side effect in 4.30 with this workarround) on a USG60W and1
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
