GS1920 missing functionality like link aggregation
I've got two GS1920 (one -24 and one -48) in my network. Both are connected to the nebula cloud.
Now I want to use options like link aggregation. It seems that nebula doesn't support these options.
But also the web gui offers my only a "VLAN" submenu if I choose "Advanced Application" in the web gui. That is the only sub menu.
Where can I activate and configure link aggregation?
Hi @Mitsch,
Just would like to inform that after a device registered on Nebula, all configuration settings needs to be control on Nebula portal.
After logging in, you may go to Switch > Configure > Switch ports, and then choose the switch ports of the switch that you would like to aggregate.
As figure below;
Click on "OK" button, to apply & save the configuration.
Tips on how to disable the link aggregation:
Reminder: After clicking on "Split" button, the link aggregation will be disabled immediately.
Hope it helps,
JonasJonas,1
Hi @Mitsch,
As figure below;
Hope it helps,
JonasJonas,1
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
