Replaced damaged switches, removed from Nebula, and now we are short on licenses
grnerd
The 4 replacement switches are not licensed, and now the entire organization has reverted to base pack, even though the 19 others have not expired. Is there a way to transfer the licenses from the damaged switches to the new switches? Unfortunately, they have been recycled, and I did not record MAC addresses or anything.
@grnerd
So those devices are not send to RMA? Since if run RMA process then license should be transferred.
Can you activate the access privilege in Nebula, Help> support request, also provide your organization name then I can check about it.
No RMA, it appears to be lightning damage. Fouts Brothers0
@grnerd
For what have seen you had remove 5 switches out of org. on April 30th, is it correct?
If there is no problem for you then I will transfer the license on these 5 switches to your replacement (4 sw)
Let me know if you have any concerns and I can PM you those switches MAC address if you need.0 -
That would be great. Let me know when it is finished.0
Any update on this?0
It is still showing Base Pack. Do I need to do something to get the Professional Pack activated again?0
@grnerd
You will need to click "upgrade now" button in License &inventory, overview tab as the screenshot.
- 441 Beta Program
- 293 Service & License
