impossible to add a device in my Nebula organisation
Best Answers
Hi @Godinne,
Thanks for your information.
The message tells you that your organization lacks of Pro/Plus license, it does not affect you to add your NWA5123-AC HD to your organization. After selecting "Acknowledge", you should be able to add your APs to the organization.
However, when you add these APs without enough license in your organization, it will be into grace period status for 15 days. If you still do not have enough license after 15 days, your organization will be back to base organization.
Let me know if there is any concern.Adam
@Godinne
Thanks for your reply.
May you provide me your organization name and enable Zyxel support at HELP > Support request page so that I will have privilege to your organization for checking license.What's the difference between PRO Organisation and Base pack ?????In short, PRO organization is able to use advanced features (with diamond icon).
However, BASE organization is unable to enable those advanced features (with diamond icon).
Switch features, for example:
Adam
Hi @Godinne,
Zyxel_AdamI don't understand, because i allready have 3 PA in my organistation (3x NWA5123-AC HD) and i never have to buy a license for them ????Now i have send back to Amazon my 3x NWA1123 ACv2 and i have received in place 3x NWA1123 AC HDBut i have the same problem for the license. But i was able to add my new AP in my organisation, and in fatc,nébula say "Your organization is in the grace period because the devices have either no license or a lower-tier license. It will be downgraded to Base Pack in 15 days. Fix now!"
@Godinne
Adam
Zyxel_AdamMy organisation is "Collège Godinne-Burnot" and it's done i have the support request activatedBàv
@Godinne
After checking your license status, you did have licenses on 3 APs, please check it on License & Inventory > Device tab
However, NWA_04 has no Nebula Pro license, so it shows N/A in license info section.
This is the main factor that NCC shows the tab messages to inform you, since NWA_04 lacks of license.
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
