USG1100 DHCP server function stopped providing IP addresses for all lans and vlans
@imaohw Can you provide the diagnostic log to me in private message for further investigation? Thanks.0
File sent by private message.
FYI - private message capability in the forum does not allow diagnostic files to be attached due to file type. I had to append .txt to the file name to "trick" the system. This should probably be fixed.0 -
@imaohw Thanks for your feedback. I have received your diagnostic file, if there is any further progress will let you know.0
Could you provide remote access to us to see more information about the root cause?I have sent a private message to you, thanks.0
I hate to necro a thread, but my USG60 started doing this yesterday. I had to reboot to get it to start serving DHCP again. Was there any fix discovered?0
splayer7 said:I hate to necro a thread, but my USG60 started doing this yesterday. I had to reboot to get it to start serving DHCP again. Was there any fix discovered?
Is your Firewall USG60 running the latest firmware on it?
Actually I had the same problem with my device, but after updating to v4.62, it seems this problem has been resolved....0 -
Hi @splayer7,
What is your firmware version of USG60?
Could you provide the diag-info log to us via private message for further investigation?
Thanks.
Hi @splayer7
Per our discussion on private message, you encounter an issue that DCHP server try to assign different IP address to client host, but it seems doesn't register MAC address for the client unless rebooting the USG60 can correct the issue.
As the below illustration, the client can’t get an IP address even the DHCP server assign an IP to the client.
About this issue, we would like to do more investigation.Can you collect the packet and DHCP debug log while the symptom occurring for us?
And provide the packet, DHCP debug log, the mac address of the client host to us via private message.
Please follow the below steps:
STEP1. Connect USB flash to your USG60.
Configuration->System->Check “Activate USB storage service”
STEP2. Check if the USB flash had been recognized by USG60.Monitor->USB StorageSTEP3. Using USB storage to collect DHCP related log.Configuration->Log & Report-> Log Settings -> USB Storage -> ActivateDouble click it -> Network -> DHCP -> choose to debug level -> press “OK”STEP4.Capture the packet USB storage.Maintenance -> Diagnostics -> select the “lan” interface to Capture Interfaces
STEP5. Retrieving the debug log of DHCP on your USB flash.
STEP6. Retrieving the packet on your USB flash.
STEP7. Please provide the packet, DHCP debug log, the mac address of the client host, diag-info log to us via private message.
Thanks for your assistance in advance!0
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 915 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
