Cant delete folder -
danko said:EXT4-fs (dm-1): error count: 2EXT4-fs (dm-1): initial error at 1606685741: htree_dirblock_to_tree:920: inode 97520594: block 390079383EXT4-fs (dm-1): last error at 1619636701: htree_dirblock_to_tree:920: inode 97520594: block 390079636It's no hardware error, but this can be your problem, a filesystem corruption.
What I have to do now?
I'm not sure. As far as I remember there is a button in the webinterface 'check volume' or 'repair volume', or something like that. Try that. If that doesn't work I have another idea.
I can not repair volume beacuse volume is OK.
Repairing is possible only if volume is dammaged.
My NAS showing that volumes are ok:
Maybe, solution is - dont touch! ?0 -
danko said:
Maybe, solution is - dont touch! ?Maybe. The problem is, the filesystem is corrupt, and you can't not touch the filesystem. Even when the box just sits there the firmware does some writes sometimes, touching the filesystem.You can watch it for a while, and regularly check if the number of errors doesn't grow.You can look at the errors withe2fsck -n /dev/md2If the number of errors grow over time, you have no choice than repairing the filesystem. -or risk loosing your content.Repairing the filesystem can be done in 2 ways. You can replace it, just delete the volume and create a new one. Of course this will kill all your files. I wrote about the other way here. Unfortunately the forum b0rked up my commands, you'll have to remove the html codes in between.
My problem is: I am no friendly with Unix...I do not know nothing about that...
I touth then this NAS is friendly for amateur using....but...
I try ssh command you said and system answer this:~ # e2fsck -n /dev/md2e2fsck 1.42.12 (29-Aug-2014)Warning! /dev/md2 is in use.ext2fs_open2: Bad magic number in super-blocke2fsck: Superblock invalid, trying backup blocks...e2fsck: Bad magic number in super-block while trying to open /dev/md2The superblock could not be read or does not describe a valid ext2/ext3/ext4filesystem. If the device is valid and it really contains an ext2/ext3/ext4filesystem (and not swap or ufs or something else), then the superblockis corrupt, and you might try running e2fsck with an alternate superblock:e2fsck -b 8193 <device>ore2fsck -b 32768 <device>
??????0 -
Oh right. You have an extra layer, a logical volume inside your raid array. In that case I don't know the device node.If you runcat /proc/mountsyou get a list of all mounts, as 'devicenode mountpoint filesystem args'. Search for the first line containing a mountpoint in /i-data/, then the corresponding devicenode has to be used with e2fsck.0
Problem solved by technical support team. They repairing file system via TeamWiever.0
- 588 USG FLEX H Series
- 477 News and Release
