[NEBULA] How can I create a 30 minutes only guest account?
Hi WebberIT,
The setting to limit the account time is In the Cloud authentication page.
After you click "+Add new user", there's a "Authorized" option for you to select.
Choose "Yes" and a new field "Expire in" will be displayed
Click "Change" and then you will be able to set a time in minutes as shown in the following picture:
The time will start to count after you create the account, and it will be set as no authorized after the time expires.1
Hi WebberIT,
The time will start to count after you create the account, and it will be set as no authorized after the time expires.1 -
Thanks, I got it now.
but it is weird that it doesn't start counting when user first login, at least thats what I thought.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
