VLANs not working on GS1900-8
Hi Zyxel community,
I’m having trouble getting VLANs to work on my Zyxel GS1900-8.
In my (test) situation, the GS1900-8 has 2 ports connected:
- On port 1, it’s connected to my Asus router with (highly configurable) Fresh tomato firmware. I have 2 VLAN’s on that router; VLAN2 and VLAN3. Those VLANS works fine together with a Zyxel NAP102 Wireless AP that's also connected to the ASUS router.
- On port 4, my Windows10 laptop.
Hardware/cables etc are fine because the 'default' situation works; if I configure the ASUS router to send untagged packages to port 1 of the Zyxel GS1900-8, and set the GS1900-8 to it’s default VLAN1 and all ports in the ‘untagged’ section.
Then I tried to set up VLANs by configuring:
- the ASUS router to send tagged VLAN2 and VLAN3 packages to the GS1900-8
- the GS1900-8 as follows: VLAN2 settings: port 1 (the Asus router) = ‘Tagged’, Trunk enabled, port 4 (my laptop) = untagged and Trunk disabled, all other ports ‘Excluded’.
However it doesn't work; f.i. from my laptop on port 4, I can’t ping the ASUS router on port 1, when I would expect them to connect via VLAN2.
Have I misconfigured something? Or could it be possible that the packaged tagged by the ASUS router aren’t compatible with the GS1900-8? The ASUS router works fine with the Zyxel NAP102 though…
Screendumps:
I would highly appreciate your help, I've spent several hours so far, with nog success…
Regards, John
Hi @UserJ,
Since you've created two similar posts, I will mainly discuss your issue on another post:
How to set up GS1900 VLAN's using a non-Zyxel router?
ThanksAdam
- 441 Beta Program
- 293 Service & License
- 461 News and Release
