forbidden message going through NO-IP url
Emerald Dragon
I am getting a forbidden message when I tried to go through the Dynamic DNS URL from No-IP.
This is what I am getting:
How do I fix this problem?
Also, the URL directs me to the login page instead of the WordPress site.
Forbidden
You don't have permission to access /pkg/WordPress/ on this server.
AFAIK that is not possible. You can change the 'main ports' in Control Panel->Network->TCP/IP->Web Configurator, but AFAIK that is only the administrative webinterface.The packages run on a different webserver, which runs on port 5000 (http) and 5001 (https) on my 520:# netstat -lptn | grep httpd
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 3674/pkg_httpd
tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 3674/pkg_httpd
tcp 0 0 0.0.0.0:5002 0.0.0.0:* LISTEN 5891/DAV_httpd
tcp 0 0 0.0.0.0:5003 0.0.0.0:* LISTEN 5891/DAV_httpd
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 7178/httpd
tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 7178/httpd
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 7178/httpdWhen you open the WordPress page in you LAN, you should see the 5000 or 5001 in the URL. If not, try to copy the URL and paste it in Notepad, or something like that. Some browsers are trying everything to hide important information in the URL.Maybe your router supports port translation. In that case you can forward port 80 WAN side to port 5000 on your NAS.
WordPress is a package, and so I think it runs on the package httpserver, which doesn't run on port 80. Did you forward the right port?
How do I do that? How do I set a different port for WordPress?0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
