how to create a vpn on ZYXEL usg20w
Did you setup correctly your windows registry for assuming that USG20 and windows are both behind a NAT?
mMontana said:Did you setup correctly your windows registry for assuming that USG20 and windows are both behind a NAT?
There should be a KB article from Zyxel.Not quite... A support campus article.
yes it was what i did already..noway it will not connect. Why so difficult??
Form mobile phone it works, so i would exclude absolutely anything router configuration related...what do you think?0 -
it seems that by default vpn connection on windows use IKE 2 while the connection on router is IKE 1..can be this th eproblem?0
Hi @stefanocpsTo address this, can we try to build the L2TP VPN connection from our Windows PC to your USG20W?If okay, please kindly share the connection information with us in a private message, the connection information contains:(1).Server IP address(2).L2TP/IPsec pre-shared key (3).user name (4). password.Or you can use another windows PC to establish L2TP VPN to USG20W and see if this symptom mainly happens on the specific PC.0
i have tried form another pc already and i have the same problem. Do you still want to try to connect to vpn anyway?0
stefanocps said:Why so difficult??A lot of pieces need to be put together to allowing a nice connection.Did you changed cypher and hash algorithm from default?Did you verify into your VPN connection the correct setup of PAP/CHAP?There's still this post as reference for doing a nice connection, unfortunately is missing the part related to NAT on both endpoints (which is quite a default in Italy)
mMontana said:stefanocps said:Why so difficult??A lot of pieces need to be put together to allowing a nice connection.Did you changed cypher and hash algorithm from default?Did you verify into your VPN connection the correct setup of PAP/CHAP?There's still this post as reference for doing a nice connection, unfortunately is missing the part related to NAT on both endpoints (which is quite a default in Italy)0
ookkkk sorry it works noW! i have unselected the other 2 protocols as in picture( somewhere else i have found that i should select them all) and also verified inside the ADVANCED tab..where there was no preshared key inserted, even if i have inserted when create connection with the new wizard. SO now ita works!
Thank you!0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 124 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 321 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 4.3K FAQ
- 93 Security Highlight
