how to create a vpn on ZYXEL usg20w
Did you setup correctly your windows registry for assuming that USG20 and windows are both behind a NAT?
not sure..i have found 2 googling, 2 keys to add to registry..but it did not change.Perhaps you can send me this setup to make sure i am ding it correctlymMontana said:Did you setup correctly your windows registry for assuming that USG20 and windows are both behind a NAT?
There should be a KB article from Zyxel.Not quite... A support campus article.
yes it was what i did already..noway it will not connect. Why so difficult??
Form mobile phone it works, so i would exclude absolutely anything router configuration related...what do you think?0 -
it seems that by default vpn connection on windows use IKE 2 while the connection on router is IKE 1..can be this th eproblem?0
Hi @stefanocpsTo address this, can we try to build the L2TP VPN connection from our Windows PC to your USG20W?If okay, please kindly share the connection information with us in a private message, the connection information contains:(1).Server IP address(2).L2TP/IPsec pre-shared key (3).user name (4). password.Or you can use another windows PC to establish L2TP VPN to USG20W and see if this symptom mainly happens on the specific PC.0
i have tried form another pc already and i have the same problem. Do you still want to try to connect to vpn anyway?0
stefanocps said:Why so difficult??A lot of pieces need to be put together to allowing a nice connection.Did you changed cypher and hash algorithm from default?Did you verify into your VPN connection the correct setup of PAP/CHAP?
There's still this post as reference for doing a nice connection, unfortunately is missing the part related to NAT on both endpoints (which is quite a default in Italy)
i have done already all these configuration on my pcmMontana said:stefanocps said:Why so difficult??A lot of pieces need to be put together to allowing a nice connection.Did you changed cypher and hash algorithm from default?Did you verify into your VPN connection the correct setup of PAP/CHAP?
There's still this post as reference for doing a nice connection, unfortunately is missing the part related to NAT on both endpoints (which is quite a default in Italy)0 -
ookkkk sorry it works noW! i have unselected the other 2 protocols as in picture( somewhere else i have found that i should select them all) and also verified inside the ADVANCED tab..where there was no preshared key inserted, even if i have inserted when create connection with the new wizard. SO now ita works!
Thank you!0
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 667 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
