Cross-LAN to share a single printer/scan
I need to share a single printer in 2 different LAN created under the zyxel usg20-vpn.
The printer is on LAN1 with 192.168.61.163 IP ADDRESS.
I create the object "PRINTER, host, 192.168.61.163"
I make a secury policy:
from lan2
to lan1,
source ANY
destinantion PRINTER
but it do not ping and do not work from LAN2.
why?
thanks a lot for your help
from lan2
to lan1,
source ANY
why?
Are you pinging by IP?
Do you have Use IPv4 Policy Route to Overwrite Direct Route checked in routing? uncheck it0 -
Hi @tyler779,Welcome to Zyxel Community.
Did you set up gateway on printer?Without gateway setting on printer, it is unable to routing back from lan1 to lan2.1 -
I tried to set gateway on printer.nothing it do not work.
I cannot ping the printer from lan2
there is an user manual where to find some screenshoots that show how to do?
thanks.
Whoa... kudos and (healthy) envy for such a so big screen, dude :-)Another way might be a 1:1 nat among networks...0
Can you see ICMP request & reply on Lan 2 interface?
Packet capture:Router> packet-trace interface lan2 extension-filter icmp
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
