port speed
In UI, you can change port configuration as 1000Mbps Full Duplex manually.
In usual it will auto negotiation as 1000M Full by default setting if without any interoperability between 2 devices.
You can check if your (1) cable (2) WAN side device are support to 1000Mbs.
The worse case, you can connect a switch between USG and your WAN side device.
thank you.CHS said:In UI, you can change port configuration as 1000Mbps Full Duplex manually.
- 603 USG FLEX H Series
- 481 News and Release
