Nsa 220 firmware
Mikael
Hi i need neu firmware to my nsa 220 i haw
| firmware version: V2.30(AFB.0) | |
| can you plz help me i use windows 10 and can get to my nsa |
There has been a later version of the firmware, 3.x when I'm not mistaken, but meanwhile the firmware is no longer on the ZyXEL server. Anyway, it didn't solve the problem you are facing now.Your problem is that W10 dropped SMB1 support, while your NAS doesn't support SMB2. You can re-enable SMB1 on Windows for the time being, but it will be obsolete and no longer available in future.1
It's hard to find that old NAS's firmware but you can try map it into Win10.
Find "Map Network Drive" in "This PC" and login your NAS's credentials.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
