FLex 100 WAN Setup Issue
Hi All
Having problems adding PPPOE details to WAN1, all I keep getting is this error..
Currently WAN1 has no IP configuration..
Performed a power cycle but no change and issue is still present in another browser on a different machine. This is a really frustrating one as it makes no sense as all I want to do is add a PPPOE login.
Best Answers
So I had to plug into another DHCP device to WAN1 that was different to the IP scope on WAN2. Then after removing I could add and save PPPOE details.
Hi @Pook,We are aware of this issue and are working on it now.We will reply you when it is done.For the workaround currently, just like you said, let WAN1 gets a DHCP IP address which will not overlap with WAN2 from local first, and you may configure PPPOE details on NCC.
Zyxel Melen0
Zyxel Melen0 -
Thanks Melen, I have a Flex 100 to set up next week and I will test :-)
- 588 USG FLEX H Series
- 477 News and Release
