Automatic Restart for LTE4506-M606
Stef
Stef Posts: 1 image  Freshman Member
Fourth Anniversary
edited January 2024 in Mobile Broadband
Hi All,
I need to restart automatically the Router LTE4506-M606 after a power loss
No parameter avaailable with the WebGui pages so perhaps thru a Telnet or ssh ?
Stef
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @Stef
    Unfortunately there is no such feature over the web GUI nor the CLI interface.
    The only related CLI command is “reboot”, but it works only when the LTE4506 has already been powered up.
    If you have any other question regarding the LTE models, please start a new discussion from the following site.
    https://homeforum.zyxel.com/
    Thank you.
    Joslyn
  • ColoMan1964
    ColoMan1964 Posts: 1 image  Freshman Member
    Hi
    I also need the router to automatically restart after powerloss. This is a big feature missing. Should be easy to add this functionality. Please add autorestart after powerloss!!!
  • Zyxel_Joslyn
    Hi @ColoMan1964
    Thanks for your suggestion.
    This forum page is related with Enterprise WLAN devices. Are you asking for Enterprise WLAN devices? If yes, could you provide which model that you use and the detail usage for the function?
    However, if you are asking for the LTE models, could you start a new discussion from the following site? We separate the model series in different forum pages to ensure all the users can find the correct discussion for the model.
    Thanks.
    Joslyn
