FLex 100 WAN Setup Issue
Pook
Pook Posts: 151  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
Hi All
Having problems adding PPPOE details to WAN1, all I keep getting is this error..
Currently WAN1 has no IP configuration..
Performed a power cycle but no change and issue is still present in another browser on a different machine. This is a really frustrating one as it makes no sense as all I want to do is add a PPPOE login.
Best Answers
  • Pook
    So I had to plug into another DHCP device to WAN1 that was different to the IP scope on WAN2. Then after removing I could add and save PPPOE details.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,523  Zyxel Employee
    Hi @Pook,
    We are aware of this issue and are working on it now.
    We will reply you when it is done.
    For the workaround currently, just like you said, let WAN1 gets a DHCP IP address which will not overlap with WAN2 from local first, and you may configure PPPOE details on NCC.
    Zyxel Melen
  • Pook
  • Zyxel_Melen
    Hi @Pook,
    Zyxel Melen
  • Zyxel_Melen
    Hi @Pook,
    The issue has been fixed, you may setup PPPOE without issue now.
    Zyxel Melen
  • Pook
    Thanks Melen, I have a Flex 100 to set up next week and I will test :-)
Nebula Tips & Tricks
