AP management VLAN vs switch settings
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
It's quick and easy to assign a management VLAN ID for the Nebula switches, but it seems to be different for the AP's.  Is setting the LAN1 port PVID the only way to do it?  That seems like it would cause some issues for the default VLAN.
  • Zyxel_Richard
    Zyxel_Richard Posts: 255 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hi TAP Tech,
    To set the management VLAN of the AP, simply select an AP in the list of [Access Point > Monitor > Access Points] to enter its detail page. After that, you can see it's management VLAN settings.
    By clicking the edit button, you can then configure its management VLAN settings
    The LAN1 setting that you see is located in another page [Access Point > Configure > AP&Port settings], which is used to configure other APs that have additional LAN ports, not for the management VLAN of AP itself.
    Best Regards,
    Richard
  • Zyxel_Richard
    Hi TAP Tech,
    Best Regards,
    Richard
  • TAPTech
    That's where it is!  Thank you so much  :)
Nebula Tips & Tricks
