Deregister an AP completely
DanielEscosa
DanielEscosa Posts: 2 image  Freshman Member
Second Anniversary
edited September 2021 in Nebula
I thought that I had deregistered some AP but at the time of reregistering them in another organization. It tells me that they are used by another user.
Could you help me
  • Zyxel_Richard
    Zyxel_Richard Posts: 255 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
    Hi Daniel,
    For the case you encountered, kindly use the "Nebula" APP on your smartphone to scan the QR Code (in the sticker of the AP) to register the AP in another organization.
    Best Regards,
    Richard
  • DanielEscosa
    Second Anniversary
    The problem is that the APs were unregistered from some options but still finding those access points in the organization.
    Could you help me or tell me the steps to completely eliminate the APs from this organization
  • Zyxel_Richard
    Hi @DanielEscosa
    When the AP is first registered in the nebula, Nebula also record it into the organization owner's account.
    Even though the AP is unregistered from the organization, this record is still kept and can't be eliminated, so that we can know in which account the device is registered in the last time. (That's why you'll see the notification when you want to register it into other organization with different owner account)
    If you want to register this AP into other organization with different owner, kindly use the QR code scanning of the APP. Through the QR code, Nebula can verify that you definitely own the device, so you can successfully register it into the new organization. Meanwhile the device owner will be changed into the new organization owner account.
    Best Regards,
    Richard
Nebula Tips & Tricks
