USG Flex 700 @ 1Gbps
@Pook
The throughput will be affect when you enable the Firewall or UTM profiles.
Since the firewall need to check and analyze each packet, therefore, it will consume numerous performance.Also, disable traffic statistic, and BWM since it could effect the throughput as well.(On-Premise)
On the datasheet, the maximum throughput@1350Mbps is measured based on (1,460-byte HTTP packets) and test done by multiple pairs.(Wan and Lan are one pair)
Thanks Charlie, where can I disable Traffic statistics and what is BWM?
I have another Flex 700 arriving today to go on another site that has a 1Gbps connection. I will run some speed tests and update the results here.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
