Any firmware updates for Armor G5
SMBv1 was deprecated in 2013. There are a handful of vulnerabilities that exist within SMBv1, most of which allow for remote code execution on the target host. Therefore, my devices use the SMBv2 and SMBv3 protocols and dlna server of Zyxel does not work in my network.1
Hi @Ghost777,Thanks for your feedback, we will further evaluation on the SMB version upgrade.About the DLNA issue, where is your DLNA server located in your environment?Could you share your topology with us?0
In my home network, all devices connected to my router, dlna service located on router0
Zyxel_Jerry said:Thanks for your feedback, we will further evaluation on the SMB version upgrade.
So... any announcement soon on WHEN the SMB will be upgraded? Or no announcement, so people cannot decide if keep the device or not?1 -
hi @Zyxel_Jerry
any news for FW update for G1 and G5 ? (and not only for FragAttack, but for update dnsmasq and other opensource package)
i hope to use my G1 again (still in the box since almost a year because of poor performance)0 -
Hi @AsgatlatThere is a firmware release recently which fix the vulnerability issue.For the opensource package, may I know which opensource package would you like to have updated?0
Hi @Zyxel_JerryZyxel_Jerry said:Hi @AsgatlatThere is a firmware release recently which fix the vulnerability issue.For the opensource package, may I know which opensource package would you like to have updated?
Seriously....
https://community.zyxel.com/en/discussion/10690/nbg6818-where-to-find-foss-details-with-version-used
Most important is DnsmasqAnd if I check support website it is still V1.00(ABSC.4)C0 for the G1, so no New update...
https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-03285&md=Armor G1 (NBG6818)#searchZyxelTab40 -
Hi @Asgatlat
On the device web gui, you can click check firmware and update to the latest firmware.
The release note will be updated in these days.0 -
NBG6818 (armor g1) firmware "v1.00(ABSC.5)C0" installed.
enabling remote assistant (wan+lan, port 443) does not seem to work (goes automatically to 'disabled' again)
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
