FYI entware samba replacment
tomtom
tomtom Posts: 3 image  Freshman Member
I install via opkg the samba replacment
to use smb2.
since I Haven t no samba access,
even the NAS utillity app doesn t work
If i remove it , all these things work again.
everybody knows why?
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Don't know why it doesn't work for you, but experiences in the past show that sometimes some lock file goes out of sync. The remedy is to symlink /opt/var/run to /var/run. In that case every lock is reset on boot.
    rm -rf /opt/var/run
    ln -s /opt/var/run /var/run
    reboot
    Don't know about the 'utility app'. Never used it.
  • tomtom
    the workaround does not work, maybe i have a special config
  • Mijzelf
    I see I made a typo.
    should be
    ln -s /var/run /opt/var/run
    If that doesn't help, try to look at the output of the start script:
    /etc/init.d/samba.sh startup
    Do you? How is your config special?
  • tomtom
    it seems, it works now. I check it the next days
