FYI entware samba replacment
tomtom
I install via opkg the samba replacment
to use smb2.
since I Haven t no samba access,
even the NAS utillity app doesn t work
If i remove it , all these things work again.
everybody knows why?
Don't know why it doesn't work for you, but experiences in the past show that sometimes some lock file goes out of sync. The remedy is to symlink /opt/var/run to /var/run. In that case every lock is reset on boot.rm -rf /opt/var/runln -s /opt/var/run /var/runrebootDon't know about the 'utility app'. Never used it.0
the workaround does not work, maybe i have a special config
I see I made a typo.ln -s /opt/var/run /var/runshould beln -s /var/run /opt/var/runIf that doesn't help, try to look at the output of the start script:/etc/init.d/samba.sh startupmaybe i have a special configDo you? How is your config special?
it seems, it works now. I check it the next days
- 588 USG FLEX H Series
- 477 News and Release
