Has anyone tried ATP on Nebula yet?
I was excited to try my spare ATP200 on Nebula, but I can't seem to get the ZTP file. When I add the firewall and setup the WAN IP's I get a little dropdown error about the VPN (but none is configured) and I can't create the ZTP file. I just get an endless loading circle on the ZTP mode section.
Has anyone tried it yet?
Has anyone tried it yet? 0
Hi @TAPTech,ATP on Nebula will be ready in mid October.It is going to release soon. Please stay tuned.
3
3 -
I have the same issue now with an USG100Flex! What to do?0
I solved it.
I deleted it from my Nebula and registered new.
What i have done is i registered the device when it was offline and made all configurations.
Then i plugged it, it loaded new firmware but i got no connection and the Deployment screen was grey as the user TAPTech above.
What i made then: Factory reset, de-register from Nebula and new registration with Nebula mobile app.
All configuration what i have done was then again there. No need for new configuration! :-)0
- 242 Nebula Ideas
- 6.8K Security
- 774 USG FLEX H Series
- 386 Security Ideas
- 59 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
