Can you stop auto firmware updates on APs?
Yes
configuration > wireless > AP management > AP policy tab then update mode to manual
Is that in Nebula or on each AP?0
That for the controller not sure about Nebula
Hi @RBrehaut,
If you are using controller, you may follow PeterUk s' steps.
About Nebula, we can’t set up firmware upgrade manually,
But there is a way, go to Site-wide>Configure>Firmware management>All APs
You may find the “New firmware is available for APs in this site.
You can reschedule upgrade time as you wish or upgrade now.”
Then set up the date you want to update firmware.
You may also set up update schedule per AP below.
Hope this can help.
Thank you for raising your questions, and wish you a nice day.
Silvia
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
