[RESOLVED] NXC2500 v4.30 - Firmware update
ssanseverino
I want to update my ZyXel NXC 2500 - wireless lan controller.
ZyXel NXC 2500 Firmware:
-Start module: V1.03
-Current version: V4.30(AAIG.0)
-Release date: 2016-07-05
The ZyXel is registered in the "myzyxel.com" platform but it does not appear in the "Firmware download" tab (this hardware may not be supported by this platform).
In "ZyXel.com" there is the latest firmware for my equipment:
-Version 6.10 (AAIG.2) C0
-Version 6.10 (AAIG.1) C0
-Version 6.10 (AAIG.0) C0
In the note for each version, the part "6 - Read me first before upgrading" is empty.
Can I do a big update from "current V4.30(AAIG.0)" to the latest "version 6.10 (AAIG.2) C0 or I need to make small update between other versions for the compatibility?
Thank's for your help
Best Answers
Is your device running or it's a.. "starting" controller?If it's running, how many AP's is managing? Can you afford a downtime of 1-3 hours after the update?The whole firmware history of NXC2500 can be found here.With all the release notes.
Assuming to have all the firmwares downloaded into your computer, maybe with only 8 APs the effective downtime will be less than 1h our, but... I personally consider also the testing, therefore 1h par update seems a small understatement. 1.5h fit a bit better, IMVHO.I'd go with this sequence:4.30 -> 5.00 -> 5.40 -> 6.00 -> 6.10 AAIG2.Don't forget to update all APs firmware at every step.Feel free to have any "staging" time among upgrades.1
Hy mMontana,mMontana said:Is your device running or it's a.. "starting" controller?If it's running, how many AP's is managing? Can you afford a downtime of 1-3 hours after the update?The whole firmware history of NXC2500 can be found here.With all the release notes.
Thank's for your help,
It's a running device with 8 APS running
it's possible to downtime for me 1 hours per days.
Regard0 -
Hi @ssanseverino ,
Yes, you can upgrade firmware from V4.30 to V6.10,
Here is the official download library of NXC2500 firmware V6.10 : https://www.zyxel.com/uk/en/support/download_library/product/nxc2500_14.shtml?c=uk&l=en&pid=20120903182114&tab=Firmware&pname=NXC2500&mtname=Firmware
Our device will have the mechanism of firmware recovery to the last good if they meet the problem applying new firmware.
That is, if there is anything problem when upgrading to V6.10, system will return to the last good firmware (in your case is V4.30).
If you have further questions, please feel free to contract us.
Wish you a nice day.
Silvia
@Zyxel_Silvia the user that made the question was @ssanseverino...0
I'm really sorry to see that currently ftp.zyxel.com and ftp2.zyxel.com are refusing connection from the public.
From my FTP client. It receives "ECONNREFUSED" when trying to connect.
@mMontana,
Yes, we disabled FTP.
Please download the file in download library.
Thank you for your sharing and wish a nice day.
Silvia0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
