Configuring a complete new organization before buying HW
Hi everyone,
I just wondered if it is possible to configure a complete multi-site new org on Nebula without buying the HW first ?
The HW is on the road and I have time now for configuring the org while delivery is in progress.
In a blank site, I'm invited to add a firewall/gateway by choosing the model but it doesn't appear in the VPN Orchestrator to prepare the future intersites VPN connections.
One other question : how will I be able to add the MAC/SN number to this firewall later when it will be delivered ?
Thanks,
Sébastien
Thanks,
Sébastien
Hi @Sébastien,
Nebula CC supports pre-configure for some settings before the device is registered/added to the site.
However, you mentioned that you would like to configure Site-to-Site VPN related settings.
To enable Site-to-Site VPN, you will need the USG FLEX added to the site on NCC.
If you have already had MAC/SN on your hand before receiving the hardware, you may register/add the MAC/SN to the site first, then you may do the pre-configuration for VPN.
For registration steps, you may refer to this link.
Hope it helps.
Hi @Sébastien,
Hope it helps.
Hi @Zyxel_Jason,
Ok so for advanced configuration I need to add a "real" device with SN/MAC first.
Thanks for your reply.
Sébastien
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
