Spontaneously reboot
2»
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    Hi @cdiaz
    It was a long time ago, it seems to me the problem was in the l2tp server, it was turned on, but not configured (there were links to remote objects, perhaps) and when opening, he swore at the policies (disabling it helped). Then there was the problem of BWM+Session Control+Antispam+SSL Inspection, when all options were enabled, the gateway was rebooted. Then it turned out that Antispam was to blame. But it was all on old firmware, for the current 4.65 Patch 0 WK32, my gateways are working stably.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @cdiaz
    Which firmware version is working on your device? You can try the latest FCS  firmware and monitor if the helps in your case.
