ZYWALL USG 20 KEEPS REBOOTING
I've been using my Zywall USG 20 for many years without any problem.
In the last few weeks it keeps rebooting, randomly, every 10/20 minutes.
No changes have been made to the firewall configuration, it's still got the original firmware.
I tried to replace the power adapter, but the problem is still there.
Any suggestions?
EDIT
Adding some info. The log shows these recurrent alerts by App Watch Dog:
- ctipd.bin is dead at (date/time)
- App watch dog recover ctipd.bin dead at the 3 time
- App watch dog stop to recover ctipd.bin. Daemon state: dead
- diagnostic-info is collecting now. Wait it to complete [*there are a few identical entries of this alert]
I noticed that, after these alerts, CPU usage keeps growing up to almost 100%, then the device reboots.
Any suggestions?
EDIT
Best Answers
Hi @luca2021
Which firmware version is working on your ZyWALL USG 20 ?
The latest version of ZyWALL USG 20 is 330BDQ.9.
We have fixed stability issues in latest release. You may have a try on it first.3 -
Hi @luca2021It's good to know the firmware is helpful in your case.In upgrade scenario, configuration will without any problem....due to all of configuration are supported in newer firmware. But we still suggest to backup configuration before firmware upgrade.
During firmware upgrade process, it may take full mins. Browser may already flush session before device boots up completely. So user may need to refresh browser after device booted up success.2
Hi @luca2021
I updated the firmware uploading the latest release you provided: everything seems back to normal and the log is not showing any alert! Thank you!
P.S. I was afraid that with a firmware update I would lose all my configuration details but I found out they are untouched, very well.
P.P.S. While updating, my browser kept showing the "Firmware upload is in progress..." progress bar in a sort of infinite loop (15 minutes had passed), but I realised the update had been done when I saw I could connect to the ZyWALL via a different browser window (leaving this comment just in case other users experience the "infinite loop", it doesn't necessarily mean it didn't work).0 -
During firmware upgrade process, it may take full mins. Browser may already flush session before device boots up completely. So user may need to refresh browser after device booted up success.2 -
Having the exact same problem on a usg-20w and a usg-20 is there a new firmware for usg-20w ?also one flex200 having uncontrolled reboots... Ill go look at the flex200 tomorrow0
AFAIK "latest" 3.30 P9 firmware is the WK48 lab firmware you can find at the link.Latest Flex 200 firmware should be 5.02(ABUI.1)C0 according to this site.
I had exactly the same error with my old Zywall USG 20. It would reboot every 25 min, with CPU going up to 100 % and "ctipd.bin is dead" message. The problem started after a reboot on October 10, 2021. Running firmware was 3.30BDQ5. Updating the firmware to 330BDQ.9. fixed the problem and everything is fine. Thanks for posting this fix.0
330BDQ.9 is quite old... 6 years AFAIK. WK48 is a bit more fresh, but not so much.
I think what Ernst_Niggli using is the elder eoled USG20 but not now days USG20-VPN. If it didn't reboot before, perhaps you try to re-configure your device. If problem still exist, it could be HW problem and you have to repair it (if the guy who sold you still have this model in stock) or upgrade to USG20-VPN instead0
Hi had the same problem, the firmware update resolved the issue. ThanksZyxel_Stanley said:Hi @luca2021
We have fixed stability issues in latest release. You may have a try on it first.0 -
Hi @Zyxel_StanleyZyxel_Stanley said:Hi @luca2021It's good to know the firmware is helpful in your case.In upgrade scenario, configuration will without any problem....due to all of configuration are supported in newer firmware. But we still suggest to backup configuration before firmware upgrade.
I have same problem with USG 100 PLUS
Model Name: ZyWALL USG100-PLUSFirmware Version: V3.00(AACV.1) / 1.17 / 2012-04-19 10:14:29It would reboot every 20 min, and "ctipd.bin is dead" message ecc. ecc.I think that ctipd.bin is corrupted or lost, could I replace/reinstall it ?Otherwise where can I find last firmware for my USG 100 PLUS ?Thanks0
- 238 Nebula Ideas
- 6.8K Security
- 754 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
