Zyxel NAS542 - EU
71m363nd3r
71m363nd3r Posts: 2 image  Freshman Member
my NAS died, but I think my HDD are untouched.
Can I swap the unite with the same model and access the data on my HDD?
tnx
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Yes. You'll only have to re-enable the non-standard shares, and do your usermanagement again. That data (which directory is a share, and which directory is just a directory, and user management) is stored in flash in the NAS itself.
  • Mijzelf
