VMG8823-B50B connect to wifi for ethernet ports usage
loredin
Hello , is that possible to have the model VMG8823-B50B connect to the router of my isp via wifi and grant internet access to its ethernet port ?
Kind Regards
Kind Regards
Hello @loredin
I don't think what you suggest would be a good idea in terms of availability, reliability and security for your connection between your VMG8823-B50B and your ISP router.
It would be more reliable and more secure for it to be a wired connection.
This would be an Ethernet WAN connectivity, as shown in the user manual, which can be downloaded from https://manual-hub.com/manuals/zyxel-vmg8825-bx0a-02-pdf-manual/
- unfortunately, the user guide is not available on the Zyxel website.
Kind regards,
Tony0
- 441 Beta Program
- 293 Service & License
