Can't see the name of the port in the mobile app
progreccor
progreccor Posts: 75 image  Ally Member
First Comment Friend Collector Nebula Gratitude Fourth Anniversary
In the previous version of the mobile app I can see the names of the ports and now there is no such ability.
  • progreccor
    here is the name in web interface
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,718 image  Zyxel Employee
    Hi @progreccor,
    Thanks for your information.
    I did a local test and I found that Android can show changed name but IOS can't.
    The port name I changed:
    The port name in mobile APP(Android/IOS):
    We start to investigate this issue and I will update when we find the root cause.
    Zyxel Melen
  • Zyxel_Melen
    Hi @progreccor,
    This issue is that IOS APP didn't show correct port name.
    We will fix this issue in next APP version.
    Zyxel Melen
  • Zyxel_Melen
    Hi @progreccor,
    Good day~
    We have released the new version which fix the port name issue.
    May you upgrade to the newest APP version? Thanks.
    Zyxel Melen
Nebula Tips & Tricks
