No access to NWA1123-AC
Hi Daniel,
We’d like to help you get the AP works well, please follow below steps:
First, reset your AP by pressing the rest button for more than 10 seconds.
You may install ZON utility on your PC connecting to same subnet with AP for checking Zyxel devices.
https://www.zyxel.com/tw/zh/products_services/Zyxel-ONE-Network-Utility-ZON-Utility/
Remind to select the right network adapter for scanning.
After AP boot up, you can access standalone mode AP GUI by default 192.168.1.2 or the DHCP IP if AP gets from dhcp server with admin/1234. The example in my ZON, the IP is 192.168.1.35 from dhcp server.
For the Nebula can’t recognize serial number, can you send the MAC and serial number via private message for me to check for you.
Thank you.
Regards,
Bella
Hi Daniel,
Thank you.
Regards,
Bella
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
