Mac Pro and XS1930-10 link aggregation
jpikoulas
jpikoulas Posts: 2 image  Freshman Member
edited August 2022 in Switch
I am trying to aggregate both mac pro ethernet ports that I connect to the XS1930-10 switch. I am creating a "virtual link aggregate" on mac pro, as per instructions found on Apple's wikis, but it is not working. I mean the aggregate bond is created OK on the mac pro, but it never gets just one IP and get online. I have done something similar with a QNAP nas and a XS1930-12 and it worked out of the box. When I have both individual ethernet ports connected to the switch, they seem to work OK. Any suggestions?
Regards,
John
  • Zyxel_CSO
    Zyxel_CSO Posts: 503 image  Zyxel Employee
    5 Answers First Comment Friend Collector Ninth Anniversary
    Hi @jpikoulas,
    Welcome to Zyxel community!
    I check the document here that macOS will use LACP when building up link aggregation.
    Have you already enabled LACP on XS1930?
    The location to see the status of link aggregation: Advanced Application > Link Aggregation.
    The place to enter LACP setting:
    Maybe you may share your setting(screenshot), so we can help you to check.
    Thanks.
    Zyxel Nebula Support
