XMG3927-B50A 5GHz Wifi dropout
@tonygibbs16@SEJ Thank you for helping out here!
Unfortunately:
- My router was already on 5.13, and still had the wifi problems.
- I tried updating several times - after reading your message - to 5.17, but always received following error after clicking "Image uploading failed. You may press 'Cancel' to upload another firmware image file, or press 'OK' to reboot to recover normal operation."
:'(0 -
Hello @mYoda
You're welcome. When I was upgrading my VMG1312-B10D, I got a similar error.
- I found that I had to switch between different browsers Firefox and Edge in order to do the software upgrade.
- see https://community.zyxel.com/en/discussion/7553/vmg1312-b10d-firmware-upgrade-error for my experiences.
I hope that this is helpful.
Kind regards,
Tony0 -
Thank you @tonygibbs16 for your support.
Unfortunately, no luck on my side: I tried on Safari/Chrome/Firefox on Mac/Android, it's simply not accepting the .bin file. #badKarmaWithZyxel
I have the same problem with the PX3321-T1, it is on firmware version V5.44(ACHK.0.2)C0
I don't know what else to do, I already changed equipment and it shows the same behavior on the 5Ghz network.
The LED goes out and the wireless network disappears for a while, then comes back as if it were a reboot, but it isn't, the power and PON network LEDs are still on.0
- 588 USG FLEX H Series
- 476 News and Release
