Setting static IP address
If you can explain what 'diagnostics' you need and how to collect them and give me an email address I may be able to accommodate your request.Zyxel_Bella said:We checked your AP's diaginfo, the communication between AP and Nebula shows these findings.
Nebula checked AP's ip status failed. AP is unable to connect Nebula.
The needed ports for Nebula management are ports 4335, 6667.
We can take a look into your ATP500’s configurations and logs.
Can you collect diagnostics of ATP500 and download its startup.conf at MAINTENANCE then send me via private message?
Thank you
Regards,
Bella
Here is the path to collect information:
At MAINTENANCE page > Diagnostics > click Collect Now > the file will show in Files tab once done.
And download startup-config.conf at File Manager for use to check your firewall rule such as port settings or IP/MAC bindings.
Thank you
Regards,
Bella
Thank you
Regards,
Bella
Bella,You had stated that you would give me an email address to send these files to. Have you provided that?0 -
Hi @ComputeInTheCloud
From your ATP500 settings, we saw that you had enabled IP/MAC Binding on MPTC_LAN_70, this feature will block those un-authorized IP/MAC address binding which may lead to certain result you saw. Please turn this feature off and have a try again.
But if you have IP/MAC Binding on you can add the AP MAC and IP out side of the DHCP range should work.0
Zyxel_Vic said:Hi @ComputeInTheCloud
This did fix the issue. I guess I do not understand what IP/Mac binding is. I thought it was the ability to set DHCP reservations for devices. Obviously that is incorrect.Zyxel_Vic said:Hi @ComputeInTheCloud
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
