NSG100 Failover Wan 2 ?
Headmaster
in Nebula
Is it possible to config the NSG100 internet connection to Failover to another router with adls/fibre by using WAN2 P2 ? Our main connection is on Wan 1 P1. Any advice or docs would be appreciated, thanks.
Best Answers
Hi @Headmaster,
Yes, you may configure internet connection to Failover by using WAN2 P2.
Please setup your PPPOE/Static IP setting for WAN2 interface on WEB GUI and then go to Nebula menu security gateway > configure > Traffic shaping to set WAN load balancing algorithm to "Failover" and prefer WAN set "WAN1".
Below is the example:
Hope it helps.Zyxel Melen0 -
Thank you Melen!0
Hi @Headmaster,
Thank you Melen!0
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 124 Nebula Status and Incidents
- 6.3K Security
- 487 USG FLEX H Series
- 321 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 454 News and Release
- 4.3K FAQ
- 93 Security Highlight
