NSG100 Failover Wan 2 ?
Headmaster
in Nebula
Is it possible to config the NSG100 internet connection to Failover to another router with adls/fibre by using WAN2 P2 ? Our main connection is on Wan 1 P1. Any advice or docs would be appreciated, thanks.
Best Answers
Hi @Headmaster,
Yes, you may configure internet connection to Failover by using WAN2 P2.
Please setup your PPPOE/Static IP setting for WAN2 interface on WEB GUI and then go to Nebula menu security gateway > configure > Traffic shaping to set WAN load balancing algorithm to "Failover" and prefer WAN set "WAN1".
Below is the example:
Hope it helps.Zyxel Melen0 -
Thank you Melen!0
Hi @Headmaster,
Thank you Melen!0
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
