GS1920-8HP adjust PoE schedule in Nebula App
Tobias3000
in Nebula
I am using GS1920-8HP to power my WIFI access points. By use of Nebula App previous release I configured the PoE schedule. Now the latest Nebula App in iPhone SE does not offer the option anymore to change the PoE schedule setting.
How can I access the PoE schedule settings for GS1920-8HP?
best regards
Tobias
best regards
Tobias
I believe there are differences between what u can do with the mobile app and the full app through a browser.
You might try accessing nebula through a browser session to see if that solves your issue.
-stew0 -
Hi @Tobias3000,
Welcome to Zyxel community!
Nebula APP is repositioned in the latest version(V3.0), please refer to this Post for more detail and the difference between V2.6 and V3.0.
Also, thanks for your feedback and the PoE schedule is already in our roadmap.
If you need to configure PoE schedule for your Switch, like @ivessm mentioned above, you may access Nebula CC web portal to configure.
The configuration page is at Switch > Configure > PoE Schedules.
Hope it helps.0
- 588 USG FLEX H Series
- 476 News and Release
