SNMP for AMG1302-T11C
johnjamesmarsh
I'm looking for an MIB or Zabbix XML for this router. The interface claims it is SNMP v3 but I cannot get Zabbix to query it successfully. Does anyone have the MIB/XML or know where I can get it?
Well I've learnt a lot about SNMP in the last couple of days and have discovered that you can create your own MIB by querying the device itself. I have done that and created the XML for Zabbix and now have my AMG1302-T11C being monitored! :-)
Hello @johnjamesmarsh
According to https://www.zyxel.cn/NewProductTab.shtml?pid=20150703120001&idx=2&c=gb&l=en the device has SNMPv1 and SNMPv2 with MIB II.
Kind regards,
Tony0 -
Thanks for the reply. I have turned off the SNMPv3 section and I am getting responses from the Zyxel with SNMPv2! I also got a full set of results from snmpwalk so I can see the data is there :-)Now all I need is an MIB file or a Zabbix XML and I will be able to interpret the data. Any ideas where I can get one of them from?1
- 588 USG FLEX H Series
- 477 News and Release
